Aa, tak, od spodu jest śruba pod klapkąOd spodu nic nie trzyma?
| Tesla
Correction code 12207006 0.12 NOTE: Unless otherwise explicitly stated in the procedure, the above correction code and FRT reflect all of the work required to perform this procedure, including the linked procedures. Do not stack correction codes unless explicitly told to do so. NOTE: See Flat...
service.tesla.com
