Please note: The low setting should only be used on smooth road surfaces, it’s not recommended to drive on this setting for long periods of time. The OnAir setting is the most comfortable, and balanced and is recommended for normal usage.
The high setting is stiffer and should only be used for going over bumps, it is not recommended to drive for long periods of time on this setting, this will cause extra wear and tear for the airbag, which will not be covered under warranty.
To mi się kłóci z poczuciem harmonii
