Teslafi i inne loggery
Gandalf
Jak wspominałem, ODB2 to nie jest, ale jest co zwiedzać, przykładowy zrzut dla dwóch samochodów (forum nakrzyczało na mnie że za dużo znaków) jednego samochodu wygląda tak:
{ "id": 000000000000, "vehicle_id": 000000000, "vin": "00000000000000000", "display_name": "MyTesLaS", "option_codes": "AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0", "color": null, "access_type": "MASQUERADE", "tokens": [ "0000000000000000", "0000000000000000" ], "state": "online", "in_service": false, "id_s": "000000000000", "calendar_enabled": true, "api_version": 14, "backseat_token": null, "backseat_token_updated_at": null, "user_id": 000000000000, "charge_state": { "battery_heater_on": false, "battery_level": 59, "battery_range": 182.49, "charge_current_request": 24, "charge_current_request_max": 24, "charge_enable_request": true, "charge_energy_added": 68.88, "charge_limit_soc": 100, "charge_limit_soc_max": 100, "charge_limit_soc_min": 50, "charge_limit_soc_std": 90, "charge_miles_added_ideal": 229.0, "charge_miles_added_rated": 285.5, "charge_port_cold_weather_mode": null, "charge_port_door_open": false, "charge_port_latch": "Blocking", "charge_rate": 0.0, "charge_to_max_range": true, "charger_actual_current": 0, "charger_phases": null, "charger_pilot_current": 24, "charger_power": 0, "charger_voltage": 0, "charging_state": "Disconnected", "conn_charge_cable": "<invalid>", "est_battery_range": 113.44, "fast_charger_brand": "<invalid>", "fast_charger_present": false, "fast_charger_type": "<invalid>", "ideal_battery_range": 146.38, "managed_charging_active": false, "managed_charging_start_time": null, "managed_charging_user_canceled": false, "max_range_charge_counter": 1, "minutes_to_full_charge": 0, "not_enough_power_to_heat": false, "scheduled_charging_pending": false, "scheduled_charging_start_time": null, "time_to_full_charge": 0.0, "timestamp": 1631995722804, "trip_charging": false, "usable_battery_level": 59, "user_charge_enable_request": null }, "climate_state": { "battery_heater": false, "battery_heater_no_power": false, "bioweapon_mode": false, "climate_keeper_mode": "off", "defrost_mode": 0, "driver_temp_setting": 23.0, "fan_status": 0, "inside_temp": 20.1, "is_auto_conditioning_on": true, "is_climate_on": false, "is_front_defroster_on": false, "is_preconditioning": false, "is_rear_defroster_on": false, "left_temp_direction": 190, "max_avail_temp": 28.0, "min_avail_temp": 15.0, "outside_temp": 13.0, "passenger_temp_setting": 23.0, "remote_heater_control_enabled": false, "right_temp_direction": 190, "seat_heater_left": 0, "seat_heater_right": 0, "side_mirror_heaters": false, "timestamp": 1631995722803, "wiper_blade_heater": false }, "drive_state": { "gps_as_of": 1631995721, "heading": 000, "latitude": 00.000000, "longitude": 00.000000, "native_latitude": 00.000000, "native_location_supported": 1, "native_longitude": 00.000000, "native_type": "wgs", "power": 0, "shift_state": "P", "speed": null, "timestamp": 1631995722804 }, "gui_settings": { "gui_24_hour_time": true, "gui_charge_rate_units": "km/hr", "gui_distance_units": "km/hr", "gui_range_display": "Ideal", "gui_temperature_units": "C", "show_range_units": true, "timestamp": 1631995722804 }, "vehicle_config": { "can_accept_navigation_requests": true, "can_actuate_trunks": true, "car_special_type": "base", "car_type": "models2", "charge_port_type": "EU", "default_charge_to_max": false, "ece_restrictions": true, "eu_vehicle": true, "exterior_color": "Pearl", "has_air_suspension": true, "has_ludicrous_mode": false, "motorized_charge_port": true, "plg": true, "rear_seat_heaters": 0, "rear_seat_type": 0, "rhd": false, "roof_color": "Glass", "seat_type": 2, "spoiler_type": "None", "sun_roof_installed": 0, "third_row_seats": "None", "timestamp": 1631995722804, "trim_badging": "90d", "use_range_badging": false, "wheel_type": "Super21Gray" }, "vehicle_state": { "api_version": 14, "autopark_state_v2": "ready", "autopark_style": "dead_man", "calendar_supported": true, "car_version": "2021.42.00.1 342064ce09e0", "center_display_state": 0, "df": 0, "dr": 0, "fd_window": 0, "fp_window": 0, "ft": 0, "homelink_device_count": 0, "homelink_nearby": false, "is_user_present": false, "last_autopark_error": "no_error", "locked": true, "media_state": { "remote_control_enabled": true }, "notifications_supported": true, "odometer": 100656.255678, "parsed_calendar_supported": true, "pf": 0, "pr": 0, "rd_window": 0, "remote_start": false, "remote_start_enabled": true, "remote_start_supported": true, "rp_window": 0, "rt": 0, "sentry_mode": false, "sentry_mode_available": true, "smart_summon_available": true, "software_update": { "download_perc": 0, "expected_duration_sec": 2700, "install_perc": 1, "status": "", "version": "0000.00.00.0" }, "speed_limit_mode": { "active": false, "current_limit_mph": 50.0, "max_limit_mph": 90, "min_limit_mph": 50, "pin_code_set": true }, "summon_standby_mode_enabled": true, "timestamp": 1631995722803, "valet_mode": false, "vehicle_name": "MyTesLaS" } }
Na tych danych wszelkiego rodzaju aplikacje opierają swoje działanie.
PS
Dla bezpieczeństwa warto rozdzielić część mającą dostęp do samochodu (TeslaPy) od dostępnego z zewnątrz przez munin-node plugina.
Norbert
PS
Ogarnąłem wirtualkę, ale mam jakiś problem z pythonem. Chyba, że to problem z autoryzacją. Muszę nad tym chwilę posiedzieć.
Gandalf
Użytkownicy TeslaPy (i nie tylko) mieli problemy z pojawiającą się i znikającą reCaptcha podczas logowania (czego oczywiście skrypty nie potrafiły obsłużyć). "Za moich czasów" problemów nie było i wciąż używam wersji, która tego nie obsługuje (headless, pre-2.0.0)
poochaty
A ktoś z Was się bawił Teslamate postawionym na Raspberry Pi, albo na jakiejkolwiek innej platformie z dockerem? Mi działa jak należy :)
slaveq
Widzisz właśnie dostałem od żony na urodziny raspberryPi 4 i chcę sobie zrobić klaster Docker Swarma z dwóch raspberry i postawić właśnie TeslaMate. Wygląda to dość sensownie, myślę, że w przyszlym tygodniu będę miał już jakieś rezultaty.
poochaty
Ciekawi mnie po co chcesz swarma. Czy nie jest wystarczające postawić dockera na jednym pi? Czy to nie strzelanie z armaty do wróbla? Jak dużą pamięć planujesz przeznaczyć na dane?
Ja mam rapsbery 4 z home assistant, który m.in. zbiera dane z Tesla, a poza tym steruje też światłami, ogrzewaniem, brama garażową itp. ;)
