Gandalf
Jak wspominałem, ODB2 to nie jest, ale jest co zwiedzać, przykładowy zrzut dla dwóch samochodów (forum nakrzyczało na mnie że za dużo znaków) jednego samochodu wygląda tak:
Na tych danych wszelkiego rodzaju aplikacje opierają swoje działanie.
PS
Dla bezpieczeństwa warto rozdzielić część mającą dostęp do samochodu (TeslaPy) od dostępnego z zewnątrz przez munin-node plugina.
"id": 000000000000,
"vehicle_id": 000000000,
"vin": "00000000000000000",
"display_name": "MyTesLaS",
"option_codes": "AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0",
"color": null,
"access_type": "MASQUERADE",
"tokens": [
"0000000000000000",
"0000000000000000"
"state": "online",
"in_service": false,
"id_s": "000000000000",
"calendar_enabled": true,
"api_version": 14,
"backseat_token": null,
"backseat_token_updated_at": null,
"user_id": 000000000000,
"charge_state": {
"battery_heater_on": false,
"battery_level": 59,
"battery_range": 182.49,
"charge_current_request": 24,
"charge_current_request_max": 24,
"charge_enable_request": true,
"charge_energy_added": 68.88,
"charge_limit_soc": 100,
"charge_limit_soc_max": 100,
"charge_limit_soc_min": 50,
"charge_limit_soc_std": 90,
"charge_miles_added_ideal": 229.0,
"charge_miles_added_rated": 285.5,
"charge_port_cold_weather_mode": null,
"charge_port_door_open": false,
"charge_port_latch": "Blocking",
"charge_rate": 0.0,
"charge_to_max_range": true,
"charger_actual_current": 0,
"charger_phases": null,
"charger_pilot_current": 24,
"charger_power": 0,
"charger_voltage": 0,
"charging_state": "Disconnected",
"conn_charge_cable": "<invalid>",
"est_battery_range": 113.44,
"fast_charger_brand": "<invalid>",
"fast_charger_present": false,
"fast_charger_type": "<invalid>",
"ideal_battery_range": 146.38,
"managed_charging_active": false,
"managed_charging_start_time": null,
"managed_charging_user_canceled": false,
"max_range_charge_counter": 1,
"minutes_to_full_charge": 0,
"not_enough_power_to_heat": false,
"scheduled_charging_pending": false,
"scheduled_charging_start_time": null,
"time_to_full_charge": 0.0,
"timestamp": 1631995722804,
"trip_charging": false,
"usable_battery_level": 59,
"user_charge_enable_request": null
"climate_state": {
"battery_heater": false,
"battery_heater_no_power": false,
"bioweapon_mode": false,
"climate_keeper_mode": "off",
"defrost_mode": 0,
"driver_temp_setting": 23.0,
"fan_status": 0,
"inside_temp": 20.1,
"is_auto_conditioning_on": true,
"is_climate_on": false,
"is_front_defroster_on": false,
"is_preconditioning": false,
"is_rear_defroster_on": false,
"left_temp_direction": 190,
"max_avail_temp": 28.0,
"min_avail_temp": 15.0,
"outside_temp": 13.0,
"passenger_temp_setting": 23.0,
"remote_heater_control_enabled": false,
"right_temp_direction": 190,
"seat_heater_left": 0,
"seat_heater_right": 0,
"side_mirror_heaters": false,
"timestamp": 1631995722803,
"wiper_blade_heater": false
"drive_state": {
"gps_as_of": 1631995721,
"heading": 000,
"latitude": 00.000000,
"longitude": 00.000000,
"native_latitude": 00.000000,
"native_location_supported": 1,
"native_longitude": 00.000000,
"native_type": "wgs",
"power": 0,
"shift_state": "P",
"speed": null,
"gui_settings": {
"gui_24_hour_time": true,
"gui_charge_rate_units": "km/hr",
"gui_distance_units": "km/hr",
"gui_range_display": "Ideal",
"gui_temperature_units": "C",
"show_range_units": true,
"vehicle_config": {
"can_accept_navigation_requests": true,
"can_actuate_trunks": true,
"car_special_type": "base",
"car_type": "models2",
"charge_port_type": "EU",
"default_charge_to_max": false,
"ece_restrictions": true,
"eu_vehicle": true,
"exterior_color": "Pearl",
"has_air_suspension": true,
"has_ludicrous_mode": false,
"motorized_charge_port": true,
"plg": true,
"rear_seat_heaters": 0,
"rear_seat_type": 0,
"rhd": false,
"roof_color": "Glass",
"seat_type": 2,
"spoiler_type": "None",
"sun_roof_installed": 0,
"third_row_seats": "None",
"trim_badging": "90d",
"use_range_badging": false,
"wheel_type": "Super21Gray"
"vehicle_state": {
"api_version": 14,
"autopark_state_v2": "ready",
"autopark_style": "dead_man",
"calendar_supported": true,
"car_version": "2021.42.00.1 342064ce09e0",
"center_display_state": 0,
"df": 0,
"dr": 0,
"fd_window": 0,
"fp_window": 0,
"ft": 0,
"homelink_device_count": 0,
"homelink_nearby": false,
"is_user_present": false,
"last_autopark_error": "no_error",
"locked": true,
"media_state": {
"remote_control_enabled": true
"notifications_supported": true,
"odometer": 100656.255678,
"parsed_calendar_supported": true,
"pf": 0,
"pr": 0,
"rd_window": 0,
"remote_start": false,
"remote_start_enabled": true,
"remote_start_supported": true,
"rp_window": 0,
"rt": 0,
"sentry_mode": false,
"sentry_mode_available": true,
"smart_summon_available": true,
"software_update": {
"download_perc": 0,
"expected_duration_sec": 2700,
"install_perc": 1,
"status": "",
"version": "0000.00.00.0"
"speed_limit_mode": {
"active": false,
"current_limit_mph": 50.0,
"max_limit_mph": 90,
"min_limit_mph": 50,
"pin_code_set": true
"summon_standby_mode_enabled": true,
"valet_mode": false,
"vehicle_name": "MyTesLaS"
PS
