S3XY - commander, buttons czy knob?
qb4hkm
Będę polował na BF na cokolwiek z commanderem, buttonsy najlepiej bo odsprzedam... chcę się nim pobawić ale nie na tyle żeby płacić 1k za to...
cooler
"With 2024.32.3 Tesla changed their power supply in the center console which means that when you exit the car, all power supply will shut off. Thats why the knob disconnects and the commander also. We are looking for a workaround for this, but it will take some time. That is why Presenting Trunk and Presenting Door are not working. Also, other automations such as Door Handles will not work.
The power supply will turn on after you sit on the driver/passenger seat. Also, it takes about 10 seconds after that to power on the Knob and Commander. We see that a lot of users with that Tesla software version are experiencing problems with their 3G internet connection and other strange behaviours. Probability, they will not rollback this version, but rather have some bug fixes with couple next releases. There is nothing to worry about.
Note: Currently, we have this version only to one of our cars, which has a rear installation of the Commander. It is not tested with front installation and not confirmed. You, guys(with front install) can try and see when you exit the car what will happen with the power of the knob and commander.
Note 2: Currently, we only found that turning Camp Mode on will keep the power on. If you notice something else which is working as a workaround, feel free to share it. Thanks"
Czytałem to, na funkcję które wymieniłem nie ma to żadnego wpływu, pewnie dlatego nie działa prezentacja bagażnika. Pociągnięcie za klamkę budzi pojazd i zasila commandera.
Generalnie totalne usypianie mi się podoba, auto autentycznie mniej traci energii na postoju bez sentry I bardzo szybko usypia.
pmlody
Dlatego wkleiłem, bo pisałeś, że nie działa prezentacja bagażnika, to jest przyczyna. Na wcześniejszej wersji testowałem i całkiem nieźle to działało.
aadam75
Zainstalowałem Commendera 2 i testuję ale teraz mam pytanie o aktualizację firmware. Nie chce mi jej ściągnąć. Mam błąd komunikacji. Macie jakieś porady?
Czy podłączyliście Commendera do Tesli jako klucz (logowanie przez konto Tesli)?
cooler
A nie włączyłeś czasem supportu dla ScanMyTesla? Wtedy commander wystawia Wifi bez neta i odcina od możliwości upgrade
aadam75
Nie, zdecydowanie tego nie ruszałem. Sparowałem tylko Teslę z Commanderem.
Po kontakcie Enhance poleciło mi po prostu zrobić reboot commandera, a w ostateczności 2 rolki w aucie.
Po pracy wrócę do tematu, bo do pracy jeżdżę rowerem, haha. Dla zdrowia.
cooler
Popieram dojazd do pracy rowerem, gratulacje! Pracuję z domu więc nie mam szans... A bez celu się nie chce jeździć.
Reboot Tesli jeżeli commandera masz connected nic nie wniesie, restart commandera nie zaszkodzi, sprawdź czy w miejscu gdzie próbowałeś upgradeować jest dobry net.
aadam75
I właśnie się zastanawiam czy to ma być net z Wifi domowego, czy 5G, czy z Tesli?
inter
5G i połączenie bluetooth z commanderem.
inter
Przyszła aktualizacja 4.8.6 do commandera. Podobno kontynuacja autopilota nie działała na GEN1.
